bug in build form files
Started by HUNK Allan, November 09, 2008, 03:05:36 AM
HUNK Allan
That is all I wanted in Chinese
Is a simple form in the document appear anywhere as long as the Chinese characters after the compiler can lead to failure
Sample:
Function FORM1_COMMAND1_BN_CLICKED (ControlIndex As Long, hWndForm As Dword, hWndControl As Dword, idButtonControl As Long) As Long
Local mystring As String
'???????' As long as the Chinese characters appear after the compiler can lead to failure
mystring="???????"    ' As long as the Chinese characters appear after the compiler can lead to failure
MsgBox mystring
Error Number =454
way ? Unicode??
You upgrade version of Chinese characters can hope for support
Hi Allan,
FireFly does not support unicode characters. FireFly 3 will not support unicode characters either. Sorry.
HUNK Allan
#2
I use a conversion methods
local udstr as string
udstr = Chr$(&HB0,&HA1) & Chr$(&HB0,&HA1) & Chr$(&H20,&H71) & Chr$(&HCE,&HD2) & Chr$(&HCA,&HC7) & Chr$(&HD6,&HD0) & Chr$(&HCE,&HC4) & Chr$(&H2E,&H2E) & Chr$(&HB0,&HA2) & Chr$(&H7A,&H21)
MsgBox udstr
I hope that the version 3.0 release as soon as possible.
Use this method it is not very satisfactory,
Despite being able to use this way to solve this problem!
In order to facilitate the preparation of the code,
I wrote a small tool for conversion.
If the program automatically shut down, you may have to close the FireFily
He did not find FireFly, will turn off automatically after 10 seconds,
The procedure for the FireFly 2.91 version.
But easily lead to long lines of code,
Will fail to compile,
"_" With more lines on it.
Local test ,test2 ,test3 As String
test=Chr$(&HD5,&HE2) & Chr$(&HB8,&HF6) & Chr$(&HCA,&HC7) & Chr$(&HD6,&HD0) & Chr$(&HCE,&HC4) & Chr$(&HC4,&HDA) _
& Chr$(&HC8,&HDD) & Chr$(&H20,&HC4) & Chr$(&HE3,&HD2) & Chr$(&HB2,&HBF) & Chr$(&HC9,&HD2) _
& Chr$(&HD4,&HD3) & Chr$(&HC3,&HC6) & Chr$(&HE4,&HCB) & Chr$(&HFB,&H75) & Chr$(&H6E,&H69) _
& Chr$(&H63,&H6F) & Chr$(&H64,&H65) & Chr$(&HD7,&HD6) & Chr$(&HB7,&HFB)
test2=Chr$(&HB5,&HB1) & Chr$(&HC8,&HBB) & Chr$(&HD2,&HB2) & Chr$(&HBF,&HC9) & Chr$(&HD2,&HD4) & Chr$(&HB4,&HF8) & Chr$(&H31,&H32) & Chr$(&H33,&H41) & Chr$(&H62,&H63)
test3=Chr$(&HD5,&HE2) & Chr$(&HB8,&HF6) & Chr$(&HB7,&HBD) & Chr$(&HB7,&HA8) & Chr$(&HCA,&HC7) & Chr$(&HB8,&HF6) & Chr$(&HB9,&HFD) & Chr$(&HB6,&HC9)
MsgBox   test & "-.-" & Chr$(&HD5,&HE2) & Chr$(&HB8,&HF6) & Chr$(&HCA,&HC7) & Chr$(&HD6,&HD0) & Chr$(&HCE,&HC4) & Chr$(&HC4,&HDA) & Chr$(&HC8,&HDD) + "-.-"+ test2 , ,test3
