Tab Orde in FF3
Started by Fraser Portwood, November 05, 2009, 10:00:54 AM
Fraser Portwood
Hi Paul, I raised a bug/support email on this, but decided to repeat here, not sure which is correct place to raise issue
In FF2 all controls were in the Tab Order view and you would create the controls according to there Tab Order.
In FF3 only Tabstop Controls are in the Tab Order, other controls are created in any order.
This means you can no longer control the order in which controls are created. which means you cannot place one control in front of another control
Hi Fraser,
Have you tried using the top menu "Format", "Order", "Bring to Front" or "Send to Back" functionality. That should correctly set the zorder of the controls.
