Don't autoclose dialogs
Started by David Martin, November 02, 2009, 08:52:25 AM
David Martin
My development machine has two monitors.  I would like to be able to have the main FireFly window on one monitor and all the others ( Workspace, Functions Library, Image Library, Reference Charts, Project Notes ) on the second monitor and viewable at all times.
Right now, for example, if I double click on a module in the Explorer tab of the Workspace it brings that code up in the editor but also closes the whole Workspace dialog.  I do not have the "Auto-Hide Workspace" option checked.
Exactly, the workspace should stay open. Works ok with "Handles and Control ID's" (F4).
Rolf
http://www.rbsoft.eu
http://www.taxifreeware.com
(W. C. Fields)
David Martin
#2
Same topic just a little more information ...
Also, when restarting FF3 have it remember the dialog settings.  Right now none of them remember I had them open.  When I manually clicked on the appropriate tab they all came back but the Image Library Manager did not go back to the second monitor where I had placed it before.
Perhaps a pushpin button in the corner like other apps use?  Then we can select what to keep open.
