Tab Order
Started by Douglas McDonald, February 10, 2010, 11:35:05 AM
Douglas McDonald
The FF3 workspace tab order is pretty cool but it would be nice if it scrolled faster or the up / down button repeated if held down. I had a large list to set the order and it took a long time just to move things up and down the list Maybe in the next revision it could be speeded up.
Thank you
Doug
Doug McDonald
KD5NWK
www.redforksoftware.com
Douglas McDonald
It would also be nice if the tab order list was numbered. for example, say the last item is 39 and its moved to 5 it should change to 5 and all the other items re-numbered accordingly
Thank you.
Doug McDonald
KD5NWK
Douglas McDonald
On more item,  Remove WS_TAPSTOP sets the tab stop and Set WS_TABSTOP removes the tap stop. Isn't this backwards??
Doug
Doug McDonald
KD5NWK
The TabStop dialog has been changed for v3.07. It now uses a checkbox to the left of each item. Checking the box enables WS_TABSTOP, unchecking the box removes the WS_TABSTOP style.
With regard to moving items in the list, I find that the fastest way is to drag and drop them using the mouse. I am not sure how else to speed up the manual, button clicking, method..........
Douglas McDonald
Great......Thank you Paul   sorry if its a little nitpicking
Doug McDonald
KD5NWK
