Changing Text and Tooltip text of Toolbar at runtime
Started by Rolf Brandt, November 23, 2009, 08:35:54 AM
How can I change the text and Tooltip text of a Toolbar at runtime?
http://www.rbsoft.eu
http://www.taxifreeware.com
(W. C. Fields)
Here is how to change the Text:
         Local tButtonInfo As TBBUTTONINFO
         Local st          As String
         st = "New Text"
         tButtonInfo.cbSize  = SizeOf(TBBUTTONINFO)
         tButtonInfo.dwMask  = %TBIF_TEXT
         tButtonInfo.pszText = StrPtr(st)
         tButtonInfo.cchText = Len(st)
         SendMessage GetDlgItem(hWndForm, IDC_FRMCLASSBUILDER_TOOLBAR1), %TB_SETBUTTONINFO, IDC_FRMCLASSBUILDER_TOOLBAR1_CLASSES, VarPtr(tButtonInfo)
With regards to the ToolTips, you will need to override the code already generated by FF3. To do that, you create your own code in the WM_NOTIFY handler and then return a FUNCTION = %TRUE from the function.
Function FRMCLASSBUILDER_WM_NOTIFY ( _
                                   hWndForm     As Dword,     _  ' handle of Form
                                   idCtrl       As Dword,     _  ' control ID
                                   ByVal pNMHDR As NMHDR Ptr  _  ' pointer to NMHDR structure
   Local pTBN            As TBNOTIFY Ptr
   Local lpToolTip       As TOOLTIPTEXT Ptr
   Local zTempString     As Asciiz * %MAX_PATH
   ' Handle any Toolbar Button tooltips
   pTBN = pNMHDR
   If @pTBN.hdr.Code = %TTN_NEEDTEXT Then
      lpToolTip = pNMHDR
      Select Case @lpToolTip.hdr.idFrom
         Case IDC_FRMCLASSBUILDER_TOOLBAR1_CLASSES:    zTempString = "ToolTip1"
         Case IDC_FRMCLASSBUILDER_TOOLBAR1_INTERFACES: zTempString = "ToolTip2"
         Case IDC_FRMCLASSBUILDER_TOOLBAR1_PROPERTIES: zTempString = "ToolTip3"
         Case IDC_FRMCLASSBUILDER_TOOLBAR1_METHODS:    zTempString = "ToolTip4"
      @lpToolTip.lpszText = VarPtr(zTempString)
      Function = %TRUE
(W. C. Fields)
