Help with Search
Started by Martin Francom, December 22, 2009, 01:54:07 PM
Martin Francom
I must be missing something.   When you do a search on this form, you will get a list of matches.   How do you go direction to the discussion for the list of matches?  I have double clicking on the match on the key works, on the simple to the right, nothing I do will move me to the discussion.
So what am i doing wrong?   How to I get to the discussion i am interested in?
I have a feeling that when I imported the old posts from the previous forum that the links in the search result terms did not come with them. I will have to re-import th eold posts again. I just did a search and all we get is a list of results but no way to actually view the details of each result (for posts in the archive forum).
Search works perfectly for me!
See attached picture.
http://www.rbsoft.eu
http://www.taxifreeware.com
(W. C. Fields)
Martin Francom
Thanks Rolf.
I thought I had clicked on all the possible places.
Yes, that works.
