Allow reorganizing of top tab bar containing forms and modules
Started by John Montenigro, November 23, 2009, 12:44:34 PM
John Montenigro
For the "someday" list?
I'd like to be able to shift the positions of which tab/module is to the left/right of others.
Nothing fancy like MS Excel, where you can just drag the tab to a new position, but maybe just add a "reorganize" function to the bottom of the dropdown box?
Robert Rioja
I agree with this suggestion.  I often use Notepad to open the project file and rearrange the order of the tabs manually.  This is very important when you have a project with many forms.
Gary Stout
Jellyfish Pro had this option..... I have used it on occasion and it is handy. Put my vote down as well.
Gary
You can now drag and drop the top tab positions (it operates like the text editor "TextPad" handles tab drag and drops).
Change will be in v3.06.
John Montenigro
