ListView HeaderDragDrop properties problem
Started by Softwise srl, January 12, 2010, 11:29:29 AM
Softwise srl
Hello,
the HeaderDragDrop  = true with FireFly 3.05 does not work.
Set to True or False is the same....
Any ideas?
Thanks
Gianmarco
You are absolutely correct. I just checked the source code and I was returning that property from hash table using "HEADERDRAPDROP" rather than "HEADERDRAGDROP".
I will include the fix in the 3.06 update that should come out tonight.
