Trapping keystrokes in a TreeView control
Started by John Waalkes, June 27, 2010, 09:11:12 PM
John Waalkes
Hi guys,
I'm trying to trap the Delete key in a TreeView control (so that I can use that to delete an item from the tree).
In the function's parameters, I see that we have this:
"ByVal lpTVKB  As TV_KEYDOWN Ptr  _  ' pointer to TV_KEYDOWN"
How do I go about using lpTVKB in my program?
Edit:
I'm able to trap the key that I want using this:
If (GetKeyState(%VK_DELETE) And &H8000) Then
   lResult& = MsgBox("Hi there")
But how would I go about using the pointer?
Thanks!
John
Something like this......
Function FRMMAIN_TREEVIEW1_TVN_KEYDOWN ( _
                                       ControlIndex  As Long,           _  ' index in Control Array
                                       hWndForm      As Dword,          _  ' handle of Form
                                       hWndControl   As Dword,          _  ' handle of Control
   Select Case @lpTVKB.wvKey
      Case %VK_DELETE
         ? "delete pressed"
      Case %VK_DOWN
         ? "down pressed"
      Case %VK_UP
         ? "up pressed"
      'case
      '  etc....
John Waalkes
