Firesplitter flickering
Started by John Messingham, July 09, 2010, 06:20:59 PM
John Messingham
Hi,
I was playing around with the firesplitter and found it to be very flickery, just wondered if there is a workaround for this.
Many Thanks
John Messingham
http://www.jmds.co.uk
Can you post a sample project showing the flicker? I don't get much flicker on my computers....maybe there is a style that needs to be set.
John Messingham
I have changed the project to use the 'ResizeRules' feature and it cures the problem. The listview headers flicker a bit so I have attached the project in case there is still more I can do.
Many Thanks
John Messingham
Some of the Microsoft Common Controls have flicker no matter what you do. For example, I could never find a way to prevent TreeViews from flickering badly whenever the Form that they are on is resized.
Turning off the redraw Class Styles for the form usually helps...for some reason FireFly defaults to on and those are the first things I turn off.
