Application Icon in DDL projects
Started by Joakim Schramm, September 22, 2010, 03:28:24 PM
Joakim Schramm
Hi!
Not sure if this is of any importance but thought to report it anyway, just in case.
I just noticed that when you creat a new DLL project in 3.09 and then opens the Project Properties dialog, the "Application Icon" frame on right side is greyed out and the "Use icon defined in Startup Form" checkbox is ticked? Also "Enable Theme support" is ticked but that one can at least be unticked (as you proably don't want that in a dll without any graphic objects).
Another observation is when I open an older dll project created in earlier FF3 build, same frame is still greyed but the checkbox is unticked, so something must have happened here between versions. As new dll is far from ready yet I don't know if this will have any impact and possibly not (easily) noticble in such case.
Also the Preview place holder diiffers that in the ticked (3.09) project it's all silver grey while the older unticked one has a darker grey square in the centre. Probably not important but includes it anyway.
Both projects uses the JR include files and PB9.04
/Joakim
