Upgrading to FF3.6 from 3.1
Started by Grant McIntosh, October 14, 2012, 11:59:02 PM
Grant McIntosh
Hi,
Currently running FF3.10 and have now gone to PBWin10, so want to install FF3.60 and latest Jose files.
FF is installed to C:\Program Files\FireFly Visual Designer\... and my files are installed on D:\My Documents\FireFly Visual Designer\...
I only have one project and it isn't really critical, more just playing to try to get the hang of things, but I'd like to keep that project if possible.
Can I just install FF3.60 over the top of FF3.10 or should I uninstall 3.10 first?
I can't really think of any reason why I'd need to use PBWin9 again, so FF3.10 is likely no longer needed.
System is running Vista Ultimate.
Thanks
Grant
PBCC6.04
PBWin10.04
FF3.70
Vista
Better to uninstall FF3.10 first. There have been several reports of people upgrading to 3.60 by overwriting their intial 3.10 install and invariably they have encountered problems. Of course, make sure to backup and save your project and then re-copy it once the new 3.6 is installed.
