GraphicControl
Started by Klaus Henn, February 09, 2013, 01:21:19 PM
Klaus Henn
If a GraphicControl is resized with the  option Strechable False , then the bitmap of the control is kept on its original size.
It would be helpful if the control would create a new bitmap with the new size.
With the current behavior I had the false impression  - the control would not reseize.
