Which Messages are ok to return %TRUE/ non-zero from
Started by Roger Garstang, June 08, 2004, 07:50:16 PM
From looking at the code generated the following messages appear to be processed after the custom messages, etc...so I'm assuming I wouldn't want to return %TRUE/non-zero as the function value for these as to allow FF's code to process.  The last three are empty in my code so far and %WM_TIMER is the only one I'm even really using of those.  Is it ok to return %TRUE to %WM_TIMER and all other messages not listed below or are there any others that I'm missing?  Just want to speed things up and return %TRUE so everything isn't passed all the way down to the default window handler.
CASE %WM_SETFOCUS
CASE %WM_SHOWWINDOW
CASE %WM_SIZE
CASE %WM_CLOSE
CASE %WM_DESTROY
CASE %WM_CTLCOLOREDIT, %WM_CTLCOLORSTATIC, %WM_CTLCOLORLISTBOX, %WM_CTLCOLORBTN
CASE %WM_NOTIFY
CASE %WM_ERASEBKGND
CASE %WM_TIMER
