Oversight - Tab Control
Started by Anonymous, June 11, 2004, 08:08:29 PM
Anonymous
The Tab Control custom properties dialog has a small buglet. It doesn't prevent operation but is slightly confusing.
If you create a number of tabs and try to assign Child Page Dialogs from the dropdown list, you find that only 5 child dialogs are displayed. No scrollbar is added to this dropdown list when you go over 5, so it looks as though you've "lost" some dialogs.
However, if you manually scroll down (using the down arrow key) you can get to the child dialog you want.
This control on the custom property dialog needs to have the scrollbar option added.
Andrew
:oops:
My mistake - I'll correct. Thanks for noticing.
