FireFly for C Language (not C++)
Started by Jean-pierre Leroy, September 22, 2014, 11:47:35 AM
Jean-pierre Leroy
I still hope that there will new version of PowerBASIC (64 bits) and also an Unicode version of FireFly.
In the meantime, I came back to C programming language (not C++) with PellesC freely available in 32 bits and 64 bits:
http://www.smorgasbordet.com/pellesc
http://www.christian-heffner.de/
I searched on the Web a visual designer or GUI designer for C and was not able to find anything really interesting. the only basic solution that could be used for small project in conjonction with PellesC is Auto C:
http://autoc.wolosoft.com/
Clearly Auto C is not as sophisticated as FireFly, and I was dreaming of a FireFly for C (Pelles C is freeware).
Due to the fact that PowerBASIC SDK Programming could be relatively easy translated to C code, do you think that could be an option in the future.
Regards,
Jean-Pierre
Rudolf Furstauer
You could use Code::Block and resedit. I use it to create applications in C.
Very powerful and for PB programmers the transition is very easy.
http://www.codeblocks.org/
http://www.resedit.net/
Jean-pierre Leroy
Hi Rudolf,
Thanks for the links to CodeBlocks and ResEdit; I will give them a try.
One of my concern was also to be able to build a library of re-usable functions; with FireFly the integrated "Functions Library" is very handy; I don't know if there is an equivalent with CodeBlocks and ResEdit ?
Regards,
Jean-Pierre
