Installing FF 3.74
Started by Christian Weilguny, July 10, 2015, 07:27:22 AM
Christian Weilguny
I have installed Ver 3.70 and tried to install 3.74. I get an error that some folders (projects, settings, etc.) are not be found and I must reinstall FireFly. I have reinstalled Ver 3.70, but I get the same Error. Thanks für helping
Have you tried doing an install using the "Local" option? If you use the My Documents option then the projects, settings folders will be created there. The Local option creates those folders off of the installation folder.
You need to do a full install of version 3.70 and then copy in the new 3.74 files overwriting some existing 3.70 files. From the sounds of your post it seems like that is what you have done. Not sure what the problem could be but I will keep thinking.
Christian Weilguny
A little bit more Information:
Initially I had installed an old Version of FF (3.09) and PB 9.05.
First I made the update to PB 10.03 and then the update to FF 3.70.
There where two installations of FF, 3.09 and 3.70.
Then I deinstalled 3.09 and tried the update to 3.74.
The System is W2k SP 4 ( I Need compatibility to W2k) in a local VMWare - Machine.
Thanks for helping
