FF_REMOVE and FF_REMOVEANY
Started by Paul Squires, August 19, 2015, 01:35:15 PM
''  FF_REMOVE
''  Return a copy of a string with characters or strings removed
''  If MatchPattern is not present in MainString, all of MainString is returned intact.
''  The replacement can cause MainString to grow or condense in size.
''  This function is case-sensitive.
Function FF_Remove( ByRef sMainString   As String, _
                    ByRef sMatchPattern As String _
                    ) As String
    Dim i As Integer
    Dim s As String
    If Len(sMainString) = 0 Then Return sMainString
    s = sMainString
    Do
        i = Instr(s, sMatchPattern)
        If i > 0 Then
           s = Left(s, i - 1) & Mid(s, i + Len(sMatchPattern))
    Loop Until i = 0
    Return s
''  FF_REMOVEANY
''  MatchPattern specifies a list of single characters to be searched for individually,
''  a match on any one of which will cause that character to be removed from the result.
Function FF_RemoveAny( ByRef sMainString   As String, _
                       ) As String
    Dim nLenMatch As Integer = Len(sMatchPattern)
    If nLenMatch = 0 Then Return sMainString
    Dim s As String =  sMainString   ' make a default return copy of the string
    Dim i As Integer
    For i = 0 To nLenMatch - 1
       s = FF_Remove( s, Chr(sMatchPattern[i]) )
    Next
    Return s
