extract embedded image
Started by Pedro Marquez, August 25, 2015, 05:22:04 PM
Pedro Marquez
As I can extract included in the project an image to another folder.
Como puedo extraer una imagen incluida en el projecto compilado a otra carpeta.
To extract the icon you have to use the ExtractIcon API function.
I don't remember at this moment how to save the icon.
Wilko Verweij
There are tools available on the internet that do that job. That way you can e.g. extract icons from Windows Explorer and re-use them (not sure if that is allowed). If you cant find them let me know.
Wilko
Pedro Marquez
Ahora tengo windows 10 y visual studio. Creo que esta sera mi despedida.
