Little suggestions
Started by Pierre Bellisle, July 31, 2022, 11:03:46 PM
Pierre Bellisle
Hey Paul,
Few suggestions, if you feel like it...
"View FUNCTION list F4" to reopen at the same place and size as before, also pos/size could be saved to the ini for next session.
Also adding an checkbox to stop the function list from closing after a double click selection.
I would like to keep it open on the IDE side. Checkbox status could be saved to ini.
"File Open Ctrl + O" dialog to open in the folder of the current selected tab file,
I know folder selection could be made inside the dialog but it seem more natural to me.
An option to reopen the files that where opened in the last session.
Was some previous version had the hability to drag and drop TABs to reorganize them?
Regard, Pierre
Hi Pierre, thanks for the suggestions. I have noted them in my files and I will consider them for the next round of WinFBE updates.
QuoteAn option to reopen the files that where opened in the last session.
Check out the "File", "Load/Save Session" options as well as the "File", "Preferences", "Environment Options", "General Options", "Restore previous session files on startup".
When that option is enabled it will automatically load the most previously used "session" that was saved by the user. If a project was last used instead of a session then the project would be opened.
QuoteWas some previous version had the ability to drag and drop TABs to reorganize them?
Hold down on the SHIFT key as you drag and drop the tabs.
Pierre Bellisle
#2
Thank Paul,
I needded to update from 220 to 301.
I like this function/bookmarks/files much better.
Reopen last session: Solved (How about an option to autosave WinFBE session on exit, so user won't have to save the session every time? (WinFBE-Last.session)
Functionlist: Solved.
TAB move: Solved.
"File Open" dialog to open in the folder of the current selected tab file: A little hope.  :~)
Regards,
Pierre
