How to use WinFBX Framework?
Started by Eros Olmi, May 04, 2023, 05:31:46 PM
Eros Olmi
Sorry, maybe dummy question but not found anything.
I've created a Windows 32Bit DLL using WinFBE and all is fine.
Later I wanted to take advantage of WinFBX framework so I just added:
#include "\afx\AfxWin.INC"
and try to compile.
Compiler say the following and I cannot get how to start with WinFBX:
Failed Compile (Errors 5  Warnings 0  [2023-05-04  09:54:39])
Failed Compile (Errors 5  Warnings 0  [2023-05-04  10:00:58])
Command Line:
C:\WinFBE_Suite\Toolchains\FreeBASIC-1.09.0-winlibs-gcc-9.3.0\fbc32.exe -m "C:\thinBasic\Lib\thinBasic_Tokenizer_FB\thinBasic_Tokenizer.bas" "C:\thinBasic\Lib\thinBasic_Tokenizer_FB\resource.rc" -v -s gui -dll -export  -x "C:\thinBasic\Lib\thinBasic_Tokenizer_FB\thinBasic_Tokenizer.dll"
FreeBASIC Compiler - Version 1.09.0 (2021-12-31), built for win32 (32bit)
Copyright (C) 2004-2021 The FreeBASIC development team.
standalone
backend:      gas
compiling:    C:\thinBasic\Lib\thinBasic_Tokenizer_FB\thinBasic_Tokenizer.bas -o C:\thinBasic\Lib\thinBasic_Tokenizer_FB\thinBasic_Tokenizer.asm (main module)
C:\WinFBE_Suite\Toolchains\FreeBASIC-1.09.0-winlibs-gcc-9.3.0\inc\Afx\CWStr.inc(1983) error 171: REDIM on UDT with non-CDECL constructor in 'REDIM PRESERVE rgwstr(LBOUND(rgwstr) TO upperBound + 1) AS CWSTR'
C:\WinFBE_Suite\Toolchains\FreeBASIC-1.09.0-winlibs-gcc-9.3.0\inc\Afx\CWStr.inc(2018) error 171: REDIM on UDT with non-CDECL constructor in 'REDIM PRESERVE rgwstr(lowerBound TO upperBound + 1) AS CWSTR'
C:\WinFBE_Suite\Toolchains\FreeBASIC-1.09.0-winlibs-gcc-9.3.0\inc\Afx\CWStr.inc(2061) error 171: REDIM on UDT with non-CDECL constructor in 'REDIM PRESERVE rgwstr(lowerBound TO upperBound - 1) AS CWSTR'
C:\WinFBE_Suite\Toolchains\FreeBASIC-1.09.0-winlibs-gcc-9.3.0\inc\Afx\CWStr.inc(2077) error 171: REDIM on UDT with non-CDECL constructor in 'REDIM PRESERVE rgwstr(lowerBound TO upperBound - 1) AS CWSTR'
C:\WinFBE_Suite\Toolchains\FreeBASIC-1.09.0-winlibs-gcc-9.3.0\inc\Afx\CWStr.inc(2089) error 171: REDIM on UDT with non-CDECL constructor in 'REDIM PRESERVE rgwstr(lowerBound TO upperBound - 1) AS CWSTR'
Eros Olmi
Sorry, my fault   :-[
I was using
inside
  Extern
  End Extern
Problem solved.
Bumblebee
All is well that compiles well  :)
Failed pollinator.
