Toolbar Editor
Started by Anonymous, November 10, 2004, 01:21:22 PM
Anonymous
The toolbar editor within FireFly needs to have its tab order sorted.
If you enter an ID for a toolbar button and press the tab key you are taken on a guided tour of the buttons (starting with the toolbar style button on the top right) before going to the tooltip field.
Logically these controls should be ordered in left to right, top to bottom order. At the moment it's not very intuitive.
Andrew
Anonymous
I should add for completeness that I'm talking about the 2nd tab, not the rebar control tab.
Andrew
Thanks Andrew - the sequence does seem to be a bit odd.
