help with pictures
Started by paulDiagnos, November 01, 2004, 01:48:51 PM
paulDiagnos
ok will do
just ave me lunch first :-)
paulDiagnos
ok i have the answer,
You have to be care ful with the bitmaps you try and switch. if you are on xp and you use xp created bitmaps it will be fine,,,
looking at headers of the bitmaps (which is what my projects is currently about), you have to have an XP compatible one.
have no i dea why this should effect anything as bitmaps are usually backwards and forwards compatible (ithink ) but there we go
thanks for looking into it i have a habit of answering my own questions
Paul
Well that is very interesting. I was wondering why the bitmap that you emailed me would not work while other bitmaps on my computer worked with no problems.
Happy to hear that the problem is solved. That's one less thing for me to worry about. :D
