How to retrieve colors of a TEXBOX ?
Started by Jean-Pierre LEROY, May 10, 2005, 05:08:23 PM
Jean-Pierre LEROY
Hi,
With FireFly I can set the ForeGround and Background colors for a specified Control with FF_Control_SetColor buit-in function.
I need a FF_Control_GetColor function to retrieve Foreground and BackGround colors of a TEXTBOX.
Do you know how I can do that in FireFly ?
Thank you.
Jean-Pierre.
It is not as easy as you would think. There is currently no built in FireFly function that does this.
It can be done. You need to retrieve the FF_PTR prop from the TextBox that you are interested in. The FF_PTR prop value is a pointer to a FF_DATA structure that is attached to every Form and Control created in FireFly.
Once you have the pointer to the FF_DATA structure, you simply need to retrieve the values from the TYPE that interest you. In this case, I assume that you want the RGB color value ????
Maybe something like the following (untested - I am writting this on-line):
Function FF_Control_GetColor (ByVal hWndControl As DWord, _
                                 ByRef ForeColor As Dword, _
                                 ByRef BackColor As Dword _
                                 ) as DWord
   Local ff_control As FF_DATA Ptr
   if iswindow(hWndControl) = 0 then exit function
   ff_control = GetProp(hWndControl, "FF_PTR")
   If ff_control = 0 Then Exit Function
   'the color will depend on whether this is a system color...
   If @ff_control.IsForeSysColor Then
       ForeColor = GetSysColor(@ff_control.ForeColorNumber)
   Else
       ForeColor = @ff_control.ForeColorNumber
   End IF
   If @ff_control.IsBackSysColor Then
       BackColor = GetSysColor(@ff_control.BackColorNumber)
   Else
       BackColor = @ff_control.BackColorNumber
   End IF
Jean-Pierre LEROY
Thank you for the FF_Control_GetColor function.
FF_Control_GetColor works well to retrieve the initial "BackColor" and "ForeColor" that I have set in the properties of the control in the FireFly User Interface.
But if I change "BackColor" and / or "ForeColor" using the FF_Control_SetColor function, the FF_Control_GetColor doesn't retrieve the new colors; FF_Control_GetColor always retrieve the initial color that I have set in the properties of the control in the FireFly User Interface.
Is it normal ?
Hmm...I wondered about that when I was playing around with those functions too.  That is probably something that needs fixed since the prop is used to set the colors on SystemColor Changes...
Jean-Pierre LEROY
Do you think the FF_Control_GetColor function will work in the next update of FF; I think this problem is related to this topic that you fixed :
http://www.planetsquires.com/forums/viewtopic.php?t=1647
Is it possible to add the FF_Control_GetColor to the FireFly function ?
Thank you.
Jean-Pierre.
The FF_Control_GetColor function has now been added....
Jean-Pierre LEROY
Thank you very much for your kind support, FireFly is becoming better and better !
Jean-Pierre
