PRJ Extension now lost???
Started by Roger Garstang, January 26, 2006, 03:01:20 AM
For some reason my FF recently lost the PRJ loading ability when double clicking the prj file.  FF opens, but not the file.  Tried setting the property off and on to associate, but no luck.
Haakon Birkeland
Here is the registry excerpt to recreate it, maybe it helps..
Beware of my path in the third and last line, which most probably differs from yours.
Windows Registry Editor Version 5.00
[HKEY_CLASSES_ROOT\.prj]
@="FireFly Visual Designer Project"
[HKEY_CLASSES_ROOT\FireFly Visual Designer Project]
[HKEY_CLASSES_ROOT\FireFly Visual Designer Project\DefaultIcon]
@="D:\\DEV\\FireFly\\FireFly.exe,0"
[HKEY_CLASSES_ROOT\FireFly Visual Designer Project\shell]
[HKEY_CLASSES_ROOT\FireFly Visual Designer Project\shell\open]
[HKEY_CLASSES_ROOT\FireFly Visual Designer Project\shell\open\command]
@="D:\\DEV\\FireFly\\FireFly.exe %1"
My keys are exactly the same, only difference is path.  Seemed to happen after last engine update.
Jean-Pierre LEROY
Roger,
I've also installed the last FF Engine and since I get the same thing as you; I'm no more able to load a FF project double clicking the prj file.
Jean-Pierre
Thansk guys, I will check into this. Hopefully put it in an update for this weekend.
This is now fixed and will be in the 2.60 update.
