Changing color of RRButton
Started by Gajanan Raje, July 16, 2006, 04:51:28 PM
Gajanan Raje
I am new to FireFly and am using FireFly trial version.
I want to be able to change color and text of a command button.  For testing purposes I have added one RRButton to a Form and am trying to change color and text on button click.
Changing the text seems to work, but changing color does not work. I tried FF_Control_Redraw after setting new color without any effect.  I also tried hiding the control, then doing FF_Control_SetColor, and then using show command.
In the beginning, RRbutton is color Red with text "Connect". After clicking I want RRButton to have color Green and text "Connected"
Below is the code:
Function FORM1_RRBUTTON1_BN_CLICKED ( _
                                   ControlIndex     As Long,  _  ' index in Control Array
                                   hWndForm         As Dword, _  ' handle of Form
                                   hWndControl      As Dword, _  ' handle of Control
                                   idButtonControl  As Long   _  ' identifier of button
  FF_Control_SetText (HWND_FORM1_RRBUTTON1,"Connected")
'   FF_Control_ShowState (HWND_FORM1_RRBUTTON1,%SW_HIDE)
  FF_Control_SetColor (HWND_FORM1_RRBUTTON1,-1,%Green)
'   FF_Control_ShowState (HWND_FORM1_RRBUTTON1,%SW_SHOW)
  FF_Control_Redraw (HWND_FORM1_RRBUTTON1)
Thanks for the help.
Gajanan Raje
The RRButton is a custom control written by Borje Hagsten. You normally need to use the messages specifically designed for that control rather than the built in FireFly Functions which work on standard Windows controls.
The messages for the RRButton are defined in the file RRBUTTON.INC and is found in the \CustomControls\Borje Hagsten\RRButton subdirectory off of your main FireFly install directory.
Here is the code that you need:
  FF_Control_SetText HWND_FORM1_RRBUTTON1, "Connected"
  SendMessage HWND_FORM1_RRBUTTON1, %RBM_SETBTNCOLOR, %Green, %TRUE
Gajanan Raje
Thanks.  I appreciate your quick response.
Gajanan Raje
