Tabs using tab key in textbox or richedit?
Started by Billy Reaves, July 24, 2006, 03:06:19 PM
Billy Reaves
i have create a small text window for the end user to type into.
and i need the tab key to work as a tab key in the textbox or richedit.
also if possible i need to be able to set the tab stop to 5 spaces.
is this possible ?
Thanks
When using single line TextBoxes, pressing the TAB key will move focus to the next control in the %WS_TABSTOP chain. You will need to create the textbox as a multiline control and press Ctrl+Tab in order to insert tab stops in your textbox.
In order to set the tab stop distance, use code like the following:
Local nDistance As Long
nDistance = 10
SendMessage HWND_FORM1_TEXT1, %EM_SETTABSTOPS, 1, VarPtr(nDistance)
Billy Reaves
Paul thanks for the quick reply.
this is the first time that i needed to use the tab key in a multi line textbox
and i was unable to find the answer i was looking for.
Thanks.
Can't wait to see version 3.
Elias Montoya
