taskbar button
Started by Rudolf Fürstauer, December 11, 2006, 05:07:24 PM
Rudolf Fürstauer
Perhaps there is a problem in FF??
I want do hide the dialog after klick on SC_MINIMIZE -
the dialog is not visible and i get the systemtrayicon,
but the button of the application is still visible in the taskbar.
There is no difference whether i use WS_EX_APPWINDOW or not.
   'minimieren des Dialog
Case %SC_MINIMIZE
   'Icon für Anwendung in Systemtray
   ti.cbSize = SizeOf(ti)
   ti.hWnd = HWND_FRMMAIN
   ti.uID = hInstMain
   ti.uFlags = %NIF_ICON Or %NIF_MESSAGE Or %NIF_TIP
   ti.uCallbackMessage = %WM_TRAYICON
   ti.hIcon = LoadImage(hInstMain, "IconMain", %IMAGE_ICON, 16, 16, %LR_SHARED)
   ti.szTip = "Application"
   Shell_NotifyIcon %NIM_ADD, ti
       ShowWindow HWND_FRMMAIN, %SW_MINIMIZE
How can i hide the application in the taskbar too??
If i create a application with the PowerBasic editor, it works.
Thanks for any help
Try the following (basically, %SW_HIDE instead of %SW_MINIMIZE):
Function FORM1_CUSTOM ( _
                     hWndForm      As Dword, _  ' handle of Form
                     wMsg          As Long,  _  ' type of message
                     wParam        As Dword, _  ' first message parameter
                     lParam        As Long   _  ' second message parameter
  Select Case wMsg
     Case %WM_SYSCOMMAND
        If wParam = %SC_MINIMIZE Then
           Local ti As NOTIFYICONDATA
           ti.hWnd             = hWndForm
           ti.uID              = App.hInstance
           ti.hIcon            = LoadImage( App.hInstance, "IconMain", %IMAGE_ICON, 16, 16, %LR_SHARED )
           '// programmatically minimize the window
           ShowWindow hWndForm, %SW_HIDE
           '// bypass the default processing of this message
           Function = %TRUE: Exit Function
Rudolf Fürstauer
Thanks Paul,
with
Function = %True
it works!
Yup, can't forget the Function= %TRUE, otherwise it still processes the message.
Shouldn't we also:
Case %WM_SYSCOMMAND
  Select Case (wParam And &HFFF0)
      Case %SC_MINIMIZE
          ShowWindow(HWND_TRAYICONAPP, %SW_HIDE) 'hide prog so it doesn't appear in the task bar.
          Function= %TRUE
From API:
"In WM_SYSCOMMAND messages, the four low-order bits of the uCmdType parameter are used internally by Windows. To obtain the correct result when testing the value of uCmdType, an application must combine the value 0xFFF0 with the uCmdType value by using the bitwise AND operator."
