LISTVIEW pointer
Started by paulDiagnos, May 05, 2009, 08:48:45 AM
paulDiagnos
Hi Guys,
Having a problem with mouse pointers
I change the mouse pointer to a cross when the mouse moves over a listview.
my problem is, that if the listview has a scroll bar (due to number of items) the mouse pointer will not change when hovering over the scroll bar.
is there a way around this? or is this a windows thing?
Paul
paulDiagnos
or what might be helpful is ...
anyone know how i can get the call backs for a specific vertical scroll >?
change the mouse that way:?
I don't know why you would not want to have the standard arrow over a scroll bar because I would think that is what most Windows users would expect.
However, you can change the cursor when the mouse moves over the non-client area of a ListView. Because FireFly already handles the subclassing for you, this is pretty damn easy.  :)
Function FORM1_LISTVIEW1_CUSTOM ( _
   Select Case wMsg
      Case %WM_NCMOUSEMOVE
         SetCursor LoadCursor(0, ByVal %IDC_CROSS)
paulDiagnos
its actually because im returning to the old dragging and dropping.
i think il have to revamp my past code as its not working as good as i would have liked!!
