Error occured creating Resource (PBR) file
Started by Jonathan Bristow, March 27, 2007, 05:18:22 AM
Jonathan Bristow
I get the error "Error occured creating Resource (PBR) file" on Firefly.  ???
All i did was add a new tool to the toolbar, then compile. I cannot see at all what is causing this, the image for the toolbar item is valid, i have checked.
I then removed the new toolbar tool icon but it still reports same error.
Since their is Zero extra information provided in error (which is infuriating) i must return here for help.
Incidentally their is no *.pbr in my working directory.
Please help  :(
Hello Jonathan,
check this item:
Topic: Error 478 - FireFly 2.80
Here occured the same problem and was solved.
Jonathan Bristow
ok, the problem was sorted, but unfortunately i didn't have time to discover the cause. I just rolled back to the previous version and made similar amendments again and it was ok.
One point to note is that i am using 2.75 of FF and not 2.80 which appears in the thread link you gave.
However thanks for your exceedingly quick response and help.
