which msg for updown control
Started by Paul D. Elliott, July 18, 2007, 04:21:00 PM
Paul D. Elliott
I put an up-down control on a form and simply want to respond to whether  the up or down
arrow got pressed.
FF created :
FUNCTION FORM2_UPDOWN1_CUSTOM ( _
                              ControlIndex  AS LONG,  _  ' index in Control Array
                              hWndForm      AS DWORD, _  ' handle of Form
                              hWndControl   AS DWORD, _  ' handle of Control
                              wMsg          AS LONG,  _  ' type of message
                              wParam        AS DWORD, _  ' first message parameter
                              lParam        AS LONG   _  ' second message parameter
                              ) AS LONG
  DIM pNMUD AS NM_UPDOWN PTR
  DIM wrkCurrent AS LONG
  DIM wrk AS STRING
  DIM cnt AS LONG
  DIM tbl(5) AS STRING
  DIM x AS LONG
  DIM fldRec AS FIELD
    IF wMsg = %WM_NOTIFY THEN
        BEEP
        IF hWndControl = HWND_FORM2_UPDOWN1 THEN
            pNMUD = lParam
            IF @pNMUD.hdr.code = %UDN_DELTAPOS THEN
                wrkCurrent = RtrnCurrent
                IF @pNMUD.iDelta = -1 THEN
                    DECR wrkCurrent
                    IF wrkCurrent < 1 THEN
                        wrkCurrent = RtrnMax
                    INCR wrkCurrent
                    IF wrkCurrent > RtrnMax THEN
                        wrkcurrent = 1
                        BEEP
... and so on
but it never beeps. The other posts in this forum keep talking only about some slider/scrolling
type of control and that confuses me to no end.
I'm guessing that I need to respond to a WM_NOTIFY msg but as I said it never beeps.
So what msg should I be checking for and do I need to check for a particular control handle?
I've only got the 1 up-down control. I'm very confused when trying to match up what is on
the PB forums with what FF wants.
Thanks.
The problem is that you are trying to catch the WM_NOTIFY in the CUSTOM handler for the UpDown control.... you should use the CUSTOM handler of the Form.
Function FORM1_CUSTOM ( _
    Local pUpDown As NM_UPDOWN Ptr
    Select Case wMsg
        CASE %WM_NOTIFY
            pUpDown = lParam
            If @pUpDown.hdr.idFrom = IDC_FORM1_UPDOWN1 Then
                If @pUpDown.hdr.code = %UDN_DELTAPOS Then
                    If @pUpDown.iDelta = -1 Then
                        MsgBox "DOWN"
                    Else
                        MsgBox "UP"
Paul D. Elliott
Ok, I was going by what routine FF sent me to when I double clicked the control.
Thanks.
:) No problem.
You just need to keep in mind that notification messages get sent to the parent of the specified control. In this case, the parent of the UpDown control is the Form.
(I shouldn't tell you but when I was working on your problem, I copied your code and spent about 10 minutes scratching my head wondering why it would work.... I checked all styles, searched the Net, searched POFFS.... any finally it struck me that the code was in the wrong CUSTOM handler)  :D
