Processing WM_KEYDOWN for Form or Control
Started by TechSupport, November 29, 2007, 01:31:43 PM
Here is some info that I just sent a customer about handling the WM_KEYDOWN message in a Form (with no controls) and for Controls themselves. I thought that maybe it would beneficial to others as well:
To capture arrow keys in a Form by itself, create a command button on the form and set its WS_VISIBLE style to FALSE (via the WindowStyles property of the command button). Go to the "Special Functions" tree branch in the FireFly Project Explorer. Select the FF_PUMPHOOK function and add code like the following below.
Function FF_PUMPHOOK(Msg As tagMsg) As Long
   'If this function returns FALSE (zero) then the processing of the regular
   'FireFly message pump will continue. Returning TRUE (non-zero) will bypass
   'the regular message pump.
   Function = %FALSE    'return %TRUE if you need to bypass the FireFly message pump
   'If you are dealing with a 'normal' OCX control then the following code will
   'allow the message to be forwarded to the OCX. Some OCX's have child windows
   'so it may be necessary to modify the GetFocus() to properly reflect the correct window.
   'If you are not using any OCX's then you can simply comment or delete this line.
   'Function = SendMessage( GetFocus(), &H37F, 0, VarPtr(Msg))
   ' Trap a keydown message for a specific form. The form itself does
   ' not have keyboard focus so we need to intercept the keyboard
   ' messages intended for the command button with WS_VISIBLE = FALSE
   Select Case Msg.hWnd
      Case HWND_FORM1_COMMAND1
         Select Case Msg.message
            Case %WM_GETDLGCODE
               Function = %DLGC_WANTALLKEYS
            Case %WM_KEYDOWN
               MsgBox "keydown"
To capture an arrow key via WM_KEYDOWN in a specific control that has focus, add code like the following below to that control's CUSTOM message handler:
Function FORM1_COMMAND1_CUSTOM ( _
   Select Case wMsg
      Case %WM_GETDLGCODE
         Exit Function
      Case %WM_KEYDOWN
         MsgBox "keydown"
The "trick" here is the %WM_GETDLGCODE message return value. We need to do this because controls in FireFly are subclassed.
