EnumWindows
Started by paulDiagnos, March 06, 2008, 07:17:34 AM
paulDiagnos
Hi guys, Im using the following code ...
EnumWindows CODEPTR(EnumWindowsProc1), 0
FUNCTION EnumWindowsProc1(BYVAL lHandle AS LONG, BYVAL lNotUsed AS LONG) PRIVATE AS LONG
        DIM gsTitle AS GLOBAL STRING
        gsTitle = STRING$(256,0)
        GetWindowText lHandle, BYVAL STRPTR(gsTitle), 256
        gsTitle = EXTRACT$(gsTitle,CHR$(0))
        Dim lResult As long
        IF LEN(gsTitle) THEN
        lResult = MSGBOX("Kill" + gstitle, %MB_OKCANCEL OR %MB_DEFBUTTON2 OR %MB_TASKMODAL, "Critical Warning")
        If lResult  %IDOK Then
        MsgBox "kill"
        sendmessage lHandle,%WM_close,0,0
        FUNCTION = %True
End FUNCTION
And im using this code to try and close a program . unfortantly the program is hidden and can be seen in the task bar.
using the above code i cant even find the window.
any ideas.
thanks Paul.
paulDiagnos
OK figured it out...
you need to find the path of the exe. not the file name, as hidden ones for somereason dont have a name.
FUNCTION ParentCallback (BYVAL hWndChild AS LONG, lRaram AS LONG) AS LONG
DIM szClass AS ASCIIZ * %MAX_PATH
DIM szText  AS ASCIIZ * %MAX_PATH
DIM lRes                AS LONG
lRes = GetClassName(hWndChild, szClass, SIZEOF(szClass))
lRes = GetWindowText(hWndChild, szText, SIZEOF(szText))
If szclass = "TPageControl" Then
Sendmessage hwndchild, %WM_ACTIVATE,%WA_CLICKACTIVE , %WA_CLICKACTIVE
TabCtrl_SetCurFocus(hwndchild, 1)
lRes = EnumChildWindows(hWndChild, CODEPTR(ChildCallback), 0&)
Function = 1
FUNCTION EnumWindowsProc (BYVAL hwnd AS LONG, BYVAL lParam AS DWORD) AS LONG
   LOCAL Path AS ASCIIZ * %MAX_PATH, TmpAsciiz AS ASCIIZ * 100
   GetPathNameFromWindowHandle hWnd, Path
If Path <> "" THEN
      GetWindowText hWnd, TmpAsciiz , SIZEOF(TmpAsciiz)
        If lcase$(path) = "c:\bluenext\bcu.exe" Then
        sendmessage hWnd,%WM_close,0,0
        End if
   FUNCTION = 1
