Label problem
Started by jcfuller, December 28, 2008, 10:31:05 AM
jcfuller
I recently purchased Firefly because of the special pricing but even at that outstanding savings, if I can't create a form like the one attached I doubt it will get much use.
I have been using this type of segregation and label stacking for decades; most recently with KetilO's resource editor (which works perfectly).
James
Hi James,
Yes, I think you're right about this one. In the Designer the zorder position for Labels does not appear to be set correctly even when using Bring to Front/Send to Back. IIRC, when creating the code generation that I set the Labels to a high zorder.... I think I did it that way to ensure that it did not interfere with the Tab Order of other controls. So, I think this could certainly be classified as a bug or limitation.
