automatically closing program if condition is met
Started by Shawn Anderson, August 31, 2009, 05:07:20 PM
Shawn Anderson
I have a program that reads the value of command$.
If command$ is blank, I want to quit the program.
How do I do that?
I've tried
Function MAINFORM_WM_CREATE ( _
                            hWndForm As Dword, _  ' handle of Form
Local clientID As String
clientID=Command$
If Trim$(clientID)="" Then
MsgBox "client ID not passed to NBSscan.exe",,$mTop
MAINFORM_WM_Destroy (hWndForm)
but that doesn't work
David Kenny
Check Command$ in FF_WinMain (found in FireFly Workspace in the special functions folder).
Paul's comments in the routine tell you what to do if you want to exit the program.
Regards,
David
Shawn Anderson
David is spot on with his advice:
Function FF_WINMAIN( ByVal hInstance     As Dword, _
                     ByVal hPrevInstance As Dword, _
                     ByVal lpCmdLine     As Asciiz Ptr, _
                     ByVal iCmdShow      As Long ) As Long
   ' If this function returns TRUE (non-zero) then the actual WinMain will exit
   ' thus ending the program. You can do program initialization in this function.
   If Len(RTrim$(Command$)) = 0 Then
      Function = %TRUE
   ' Function = %FALSE    'return %TRUE if you want the program to end.
