TREEVIEW CHECKBOX
Started by Brian Chirgwin, September 14, 2009, 10:40:25 PM
Brian Chirgwin
Using the treeview control, how do you get notifications that a checkbox was clicked on (checked/unchecked)?
I have the code the set the checkbox state (checked/unchecked), but I haven't figured out how to get notifications when a user clicks a checkbox in a treeview.
Any help in the right direction would be appreciated.
David Kenny
#1
Brian,
You check the %UM_CHECKSTATECHANGE message (that you posted).  Sound strange, but read on.  The sample code below is the entire Custom routine for the form that contains the TreeView. You need to check the NM_Click message to see if it was on a checkbox an post the %UM_CHECKSTATECHANGE msg if it was.  And then, of course, process the %UM_CHECKSTATECHANGE msg. You may also notice it's a Tri-State checkbox being used here.
Function FORM1_CUSTOM ( _
  Local pNMTV As NM_TREEVIEW Ptr
  Local sText As String
  Local nLine As Long
  Select Case wMsg
     Case %WM_NOTIFY
         pNMTV = lParam
         Select Case @pNMTV.hdr.idfrom
              Case IDC_FORM1_TREEVIEW1      ' notify message from the treeview control
                  Select Case @pNMTV.hdr.code
                        Case %TVN_SELCHANGED
                        Case %NM_CLICK    'left click
              Local ht As TV_HITTESTINFO
              Local dwpos As Dword
              Local iTmp As Integer
              dwpos = GetMessagePos()
              iTmp = LoWrd(dwpos)
              ht.pt.x = iTmp
              iTmp = HiWrd(dwpos)
              ht.pt.y = iTmp
              Call MapWindowPoints(%HWND_DESKTOP, @pNMTV.hdr.hWndFrom, ht.pt, 1)
              Call TreeView_HitTest(@pNMTV.hdr.hwndFrom, ht)
              If ht.flags = %TVHT_ONITEMSTATEICON Then
                PostMessage hWndForm, %UM_CHECKSTATECHANGE, @pNMTV.hdr.hWndFrom, ht.hItem
                        Case %NM_DBLCLK   'left double-click
                        Case %NM_RCLICK   ' right click
                        Case %NM_RDBLCLK   'right double-click
Case %UM_CHECKSTATECHANGE
Local TVITEM_ As TV_ITEM
Local lState As Long
TVITEM_.mask  = %TVIF_STATE Or %TVIF_HANDLE Or %TVIF_CHILDREN
TVITEM_.hItem = LParam
TVITEM_.stateMask = %TVIS_STATEIMAGEMASK
TreeView_GetItem WParam, TVITEM_
lState = TVITEM_.State
Shift Right lState, 12
If lState = 3 Then
  TVITEM_.State = IndexToStateImageMask(1)
  TreeView_SetItem WParam, TVITEM_
  lState = 1
ChangeChildState WParam, LParam, lState
ChangeParentState WParam, LParam, lState
This Microsoft link also contains useful information, though the sample code is in C.:
http://support.microsoft.com/kb/261289
David
