Default font for controls
Started by Nathan Durland, November 11, 2009, 06:42:09 PM
Nathan Durland
I'd like to change the default font used for new controls to Tahoma 10 regular.  I pick it in "tools / environment / visual Designer", but it won't "stick".  I pick the new font, then click OK.  When I go back in and look, the setting is the original value.  I see a new FireFly.ini file get created in the program folder (c:\firefly3\settings), but it reads the standard "MS Sans Serif..."
Hi Nathan,
Right you are. That is a bug.
It is now fixed. Fix will be in v3.03.
