Search Function and the Tab Bar
Started by Richard Marchessault, November 21, 2009, 10:22:05 AM
I have many forms and modules in my project. All the tabs for these will not fit on the tab bar. That is not a problem.
When I search the entire project for text, it is found and highlighted. The tab for the component that contains the code is highlighted. However, if that tab is not currently visible on the tab bar, then there is no clear indication of which form or module contains the code that was found. It would really help to scroll the tab bar to bring the tab for the form or module that contains the found code into view.
Another improvement would be to have the active tab highlighted in the drop down list of tabs.
Dick
