Initialize my control
Started by Stephane Fonteyne, December 08, 2009, 06:40:04 PM
Stephane Fonteyne
Dear developers,
I don't find the WM_INITIALIZE message in FF3. How can I setup my trackbars to the defaults values when the program is loaded in memory? What FF3 function do I have used for setup my trackbars to move down all?
Thanks
Stephane
Stephane Fonteyne
Ba. Elektronica - ICT
GSM : +32-xxxxxxxxxx
John Montenigro
I've been searching my SDK and other WinAPI resources, and I haven't found such a message. Are you sure it's WM_INITIALIZE and not WM_INITDIALOG???
Stephane Fonteyne
Stephane Fonteyne
John Montenigro
Would it make sense to put your setup in the WM_CREATE of the form?
Or, in the special module FF_AppStart?
Use WM_CREATE for the Form that the controls are on. WM_INITDIALOG is used when you emply the dialog functionality of Windows (which is what PB's DDT uses). FF3 uses the CreateWindowEx approach so it uses WM_CREATE.
The initial TrackBar properties can be set using FireFly's PropertyList rather than having to do it via code.
