Programatically changing tabs on the tab control
Started by David Kenny, March 02, 2010, 01:30:16 PM
David Kenny
I needed to open my settings dialog and activate a particular tab.
This worked to change the tab: (this is in the WM_CREATE of the form that contains the tab control)     FF_TabControl_SetSelectedTab( HWND_SETTINGS_TABCONTROL1, 1 ) 'Show the File Locatations Tab
The tab label changed to tab 1, but the tab client area stayed on tab 0. After much playing around I found I needed to add a line:     FF_TabControl_SetSelectedTab( HWND_SETTINGS_TABCONTROL1, 1 ) 'Show the File Locatations Tab
     ShowWindow(HWND_FILELOCTAB,%True)
I can provide a demo FF project if needed.
Is there a better way to do this?
David Kenny
Use this function:
FF_TabControl_SetTabFocus( HWND_SETTINGS_TABCONTROL1, 1 )
http://www.rbsoft.eu
http://www.taxifreeware.com
(W. C. Fields)
David Kenny
Spot-on Rolf.  I tried that that routine, but I must have had one of the parameters wrong or was calling it in the wrong place.
Thanks!
Best regards,
David Kenny
