Cut and Paste
Started by Martin Francom, March 05, 2010, 02:50:23 AM
Martin Francom
Has anyone else notice a problem with "copy and paste"  ?
When I use the mouse to copy and paste a block of code,  the code seams to get pasted above where you expect it will get pasted.  If I use the keyboard to copy (Cntl-Insert) and paste (Shift-Insert)  then it works correctly.  Only has problem if I use the mouse (Rt-Button) Copy and (Rt-Button) Paste.
Oh,  note this only happens when I am replacing text (hightlight text then Rt-Button Paste).
Yes, I have experienced that problem too, exactly as you describe it. A work around is to first delete the hightlghted text that is to be replaced. Simply press the Del button before pasting.
I think this was mentioned already in another thread.
http://www.rbsoft.eu
http://www.taxifreeware.com
(W. C. Fields)
