Stay with property
Started by Marc van Cauwenberghe, May 14, 2010, 11:03:14 AM
Hello Paul,
A feature that I quite like is the fact that if you edit a property of a control and you go to an other control you also go to the same property.
Is this possible?
Marc
Sounds like a good idea. I'll put it on my list.
David Warner
I would have found this handy myself a few times recently. I'm glad it's on the list.  :)
Elias Montoya
Ditto!
May i suggest a "save this config" and a "reset to default" button for property states as well?
Quote from: Elias Montoya on May 14, 2010, 03:39:19 PM
Ditto!
I already have "Favorite Styles" on the wish list. I started to implement during the FF3 beta period but I got bogged down in the complexity of it so I set it aside for later..... that was 6 months ago. :)
That was really top on my list  :(
I must admit that it became more complex than I had envisioned it.
Hope it will get in there at some point.
