Firesplitter issue
Started by Elias Montoya, May 24, 2010, 10:02:46 PM
Elias Montoya
Firesplitter works. Except in some obscure situations that i dont understand.
Works if you put the control in main window... or in a child window.
It doesnt work if you put it inside a child window that is part of a Tab control.
Full situation is:
Main Window>Firesplitter>Section 2 window>Tab Control>Tab #3's child window>Firesplitter>Does not display handles or dialogs inside.
Martin Francom
Elias Montoya
