show pdf file
Started by Marc van Cauwenberghe, January 14, 2010, 01:19:35 PM
Hello,
Could anybody help me here. I want to show a pdf file in my application. It should not be inside the application. Calling the pdf assosiated program is ok.
Thanks for any help.
Marc
ShellExecute API should work. I use: ShellExecute(HWND_FORM, ByVal 0, fileToOpenZ, ByVal 0, ByVal 0, %SW_Show)
I just love this forum!!!
Thank you very much Roger.
Marc
Robert Rioja
I use the Foxit Reader SDK ActiveX component which is free from Foxit.com  They also have a version that you have to pay for with more features.  But the free version is a full featured PDF reader that you can incorporate into any application.  I use it as a control in a form.  Works very well.
Robert
Haakon Birkeland
Haakon 8o)
Exactly! On the download site they have the developer kit.
http://www.foxitsoftware.com/downloads/index.php
http://www.rbsoft.eu
http://www.taxifreeware.com
(W. C. Fields)
I got a Dev license of Quick PDF a few years back with plans to convert to PB, but it never panned out.  Looks like they changed yet again and started their own site wanting money to upgrade to the most recent.  One other trick I thought of was putting a browser window in your app and opening it with the browser which if linked should put Acrobat inside the browser.
Douglas McDonald
#7
Here is a PB program to display a .PDF Its a .exe for testing but I use it as a .dll
At least it will point you in the correct direction. NOTE this works with Acrobat 6, haven't tested it with other versions.
You don't need any 3rd party stuff. The acrobat reader installs any .dll's called and that's free..............
Doug
  #COMPILE EXE
  #INCLUDE "WIN32API.INC"
  DECLARE FUNCTION WndProc (BYVAL hWnd AS DWORD, BYVAL wMsg AS DWORD, _
                            BYVAL wParam AS DWORD, BYVAL lParam AS LONG) AS LONG
  %WM_FORWARDMSG = &H37F ' (895)
  %IDC_PDF   = 1001
  DECLARE FUNCTION AtlAxWinInit LIB "ATL.DLL" ALIAS "AtlAxWinInit" () AS LONG
  DECLARE FUNCTION AtlAxWinTerm () AS LONG
    UnregisterClass ("AtlAxWin", GetModuleHandle(BYVAL %NULL))
  DECLARE FUNCTION AtlAxGetControl LIB "ATL.DLL" ALIAS "AtlAxGetControl" _
     ( _
     BYVAL hWnd AS DWORD, _   ' [in] A handle to the window that is hosting the control.
     BYREF pp AS DWORD _      ' [out] The IUnknown of the control being hosted.
  ) AS DWORD
' Puts the address of an object in a variant and marks it as containing a dispatch variable
  SUB AtlMakeDispatch ( _
     BYVAL lpObj AS DWORD, _                        ' Address of the object instance
     BYREF vObj AS VARIANT _                        ' Variant to contain this address
     ) EXPORT
     LOCAL lpvObj AS VARIANTAPI PTR                 ' Pointer to a VARIANTAPI structure
     LET vObj = EMPTY                               ' Make sure is empty to avoid memory leaks
     lpvObj = VARPTR(vObj)                          ' Get the VARIANT address
     @lpvObj.vt = %VT_DISPATCH                      ' Mark it as containing a dispatch variable
     @lpvObj.vd.pdispVal = lpObj                    ' Set the dispatch pointer address
' Program entrance
  FUNCTION WINMAIN (BYVAL hInst AS DWORD, BYVAL hPrevInstance AS DWORD, _
                    BYVAL lpszCmdLine AS ASCIIZ PTR, BYVAL nCmdShow AS LONG) AS LONG
    LOCAL hDlg           AS DWORD
    LOCAL hPdf           AS DWORD
    LOCAL wcex           AS WndClassEx
    LOCAL szClassName    AS ASCIIZ * 256
    LOCAL szTitle        AS ASCIIZ * 256
    LOCAL rc             AS RECT
    LOCAL pUnk           AS DWORD
    LOCAL oPdf           AS DISPATCH
    LOCAL vVar           AS VARIANT
    szClassName        = "sk_pdf01"
    wcex.cbSize        = SIZEOF(wcex)
    wcex.style         = 0 '%CS_DBLCLKS OR %CS_HREDRAW OR %CS_VREDRAW
    wcex.lpfnWndProc   = CODEPTR(WndProc)
    wcex.cbClsExtra    = 0
    wcex.cbWndExtra    = 0
    wcex.hInstance     = hInst
    wcex.hCursor       = LoadCursor (%NULL, BYVAL %IDC_ARROW)
    wcex.hbrBackground = %COLOR_3DFACE + 1
    wcex.lpszMenuName  = %NULL
    wcex.lpszClassName = VARPTR(szClassName)
    wcex.hIcon         = LoadIcon (%NULL, BYVAL %IDI_APPLICATION)
    wcex.hIconSm       = LoadIcon (%NULL, BYVAL %IDI_APPLICATION)
    CALL RegisterClassEx (wcex)
    SystemParametersInfo %SPI_GETWORKAREA, 0, BYVAL VARPTR(rc), 0
    szTitle = "PDF Test"
    hDlg = CreateWindowEx (%WS_EX_CONTROLPARENT, szClassName, szTitle, _
           %WS_OVERLAPPEDWINDOW, rc.nLeft, rc.nTop, rc.nRight - rc.nLeft + 2, _
           rc.nBottom - rc.nTop + 1, 0, 0, hInst, BYVAL %NULL)
    AtlAxWinInit   ' // Initializes ATL
    GetClientRect hDlg, rc
    hPdf = CreateWindowEx(0, "AtlAxWin", "PDF.PdfCtrl.5", _
           %WS_CHILD OR %WS_VISIBLE OR %WS_TABSTOP OR %WS_BORDER, _
           rc.nLeft, rc.nTop, rc.nRight - rc.nLeft, rc.nBottom - rc.nTop, _
           hDlg, %IDC_PDF, hInst, BYVAL %NULL)
    AtlAxGetControl(hPdf, pUnk)
    AtlMakeDispatch(pUnk, vVar)
    SET oPdf = vVar
'*****pass the file name you want***********
    vVar = "c:\audiofile\cfa_635_v1.4.pdf" ' "D:\TTDS\Server_v1-2.pdf"   ' <-- change
    OBJECT CALL oPdf.LoadFile(vVar)
    SetFocus hPdf
    ShowWindow hDlg, nCmdShow
    UpdateWindow hDlg
    OBJECT CALL oPdf.PrintWithDialog
    LOCAL uMsg AS tagMsg
    WHILE GetMessage(uMsg, %NULL, 0, 0)
       TranslateMessage uMsg
       DispatchMessage uMsg
    WEND
    AtlAxWinTerm   ' // Uninitializes ATL
    SET oPdf = NOTHING
    FUNCTION = uMsg.wParam
' Main Window procedure
    LOCAL rc AS RECT
    SELECT CASE wMsg
       CASE %WM_SIZE
          MoveWindow GetDlgItem(hWnd, %IDC_PDF), 0, 0, LOWRD(lParam), HIWRD(lParam), %TRUE
          FUNCTION = 0 : EXIT FUNCTION
       CASE %WM_DESTROY
          PostQuitMessage 0
    FUNCTION = DefWindowProc(hWnd, wMsg, wParam, lParam)
Doug McDonald
KD5NWK
www.redforksoftware.com
That is an old example I posted in August 2003. The AtlMakeDispatch funcion it uses is not suitable for the new compilers because it does not increment the reference count (I had to do it this way because of a bug in PB 7.0). When PB 8.x was released, I posted the following modification in the next message of the same thread (in September, 2005):
With the PBWin 8.x compiler, when the "home made" dispatch variant goes
out of scope, is set to empty or you assign a new value to it, the
reference counter is decreased, so we need to increment the count with
IUnknown_AddRef to keep the reference count balanced.
Just replace the AtlMakeDispatch procedure with the following:
' The IUnknown::AddRef method increments the reference count for an interface on an object. It
' should be called for every new copy of a pointer to an interface on a given object.
FUNCTION IUnknown_AddRef (BYVAL pthis AS DWORD PTR) AS DWORD
    LOCAL DWRESULT AS DWORD
    IF ISFALSE pthis THEN EXIT FUNCTION
    CALL DWORD @@pthis[1] USING IUnknown_AddRef(pthis) TO DWRESULT
    FUNCTION = DWRESULT
SUB AtlMakeDispatch (BYVAL lpObj AS DWORD, BYREF vObj AS VARIANT) EXPORT
   IUnknown_AddRef lpObj                          ' Increment the reference counter
It should be noted that hosting Acrobat Reader directly you will experience some repainting problems. Because this control has been designed to work mainly with Internet Explorer, I found that it was a better way to use ATL or my OLE container to host the WebBrowser control and then use it to load the .pdf file.
For those using my include files, there are a couple of examples in my forum that illustrate how to do it: the first one using ATL, the second one using my OLE Container.
WebBrowser Control: Embedding Acrobat Reader
http://www.jose.it-berater.org/smfforum/index.php?topic=2710.0
Haakon Birkeland
Foxit doesn't have a very interesting pricing model on the SDK!
Haakon 8o)
Not anymore - they used to have the basic edition for free.
(W. C. Fields)
Douglas McDonald
Jose,
I know this is an old thread but somehow I missed it. I just want to say thanks for explaining the code was for pb7. and you have modified it since then. As you can guess It worked perfectly as it is in use everyday. If i have the need I'll change my code to reflect your changes. But...if its not broke don't fix it.
BTW, at the top of the code, header, I did give you credit. I should have pasted that also. Sorry
Thank you
Doug
Doug McDonald
KD5NWK
Robert Rioja
#13
Foxit does have a free PDF reader that is a good replacement for the Acrobat reader.  It is much faster and takes up a lot less resources (disk space, memory, etc.).  It comes with an OCX that can be used in FireFly or even VB.  I have used it successfully.  They also sell an SDK and they used to give a free eval, but no more.  Just use the OCX that comes with their free reader and it works great with FireFly.
Robert
