Sample code won't compile
Started by Paul Breen, March 16, 2005, 05:09:00 PM
Paul Breen
The calc project won't compile. Gives the message "missing declaration clipboardst". I would normally suspect an include file but it would'nt have gotten this far would it?
The sample code in the PowerDev demo compiles nicely thank you. :lol:
Smiley will change if it's my fault.  :oops:
Paul Breen
Quote from: Paul BreenThe calc project won't compile. Gives the message "missing declaration clipboardst".
You need to uncheck the "Use #DIM ALL" option under "Environment Options". I updated the samples weeks ago but the new ones won't be available until I release the next update (which is getting closer and closer).
QuoteThe sample code in the PowerDev demo compiles nicely thank you. :lol:
ha ha ha ha  :)
Paul Breen
