FreeBasic: Manifests
Started by José Roca, August 26, 2015, 11:21:04 PM
Wasn't able to compile my Free Basic tests adding a resource with a manifest. The problem was that although the Microsoft documentation says that you have to use "ia64" in the processorArchitecture field, in fact this setting is for servers; for desktop computers we have to use "amd64".
Manifest for 64 bit:
<?xml version="1.0" encoding="UTF-8" standalone="yes"?>
   <assembly xmlns="urn:schemas-microsoft-com:asm.v1" manifestVersion="1.0" xmlns:asmv3="urn:schemas-microsoft-com:asm.v3">
      <assemblyIdentity version="1.0.0.0"
         processorArchitecture="amd64"
         name="ApplicationName"
         type="win32"/>
      <description>Optional description of your application</description>
      <asmv3:application>
         <asmv3:windowsSettings xmlns="http://schemas.microsoft.com/SMI/2011/WindowsSettings">
            <dpiAware>true</dpiAware>
         </asmv3:windowsSettings>
      </asmv3:application>
      <!-- Compatibility section -->
      <compatibility xmlns="urn:schemas-microsoft-com:compatibility.v1">
         <application>
            <!--The ID below indicates application support for Windows Vista -->
            <supportedOS Id="{e2011457-1546-43c5-a5fe-008deee3d3f0}"/>
            <!--The ID below indicates application support for Windows 7 -->
            <supportedOS Id="{35138b9a-5d96-4fbd-8e2d-a2440225f93a}"/>
            <!--This Id value indicates the application supports Windows 8 functionality-->
            <supportedOS Id="{4a2f28e3-53b9-4441-ba9c-d69d4a4a6e38}"/>
            <!--This Id value indicates the application supports Windows 8.1 functionality-->
            <supportedOS Id="{1f676c76-80e1-4239-95bb-83d0f6d0da78}"/>
         </application>
       </compatibility>
      <!-- Trustinfo section -->
      <trustInfo xmlns="urn:schemas-microsoft-com:asm.v2">
         <security>
            <requestedPrivileges>
               <requestedExecutionLevel
                  level="asInvoker"
                  uiAccess="false"/>
               </requestedPrivileges>
         </security>
      </trustInfo>
      <dependency>
         <dependentAssembly>
            <assemblyIdentity
               type="win32"
               name="Microsoft.Windows.Common-Controls"
               version="6.0.0.0"
               publicKeyToken="6595b64144ccf1df"
               language="*" />
         </dependentAssembly>
      </dependency>
   </assembly>
Manifest for 32 bit:
         processorArchitecture="x86"
         type="win32"/>
      <asmv3:application>
         <application>
         </application>
       </compatibility>
         <security>
                  level="asInvoker"
                  uiAccess="false"/>
         </security>
      </trustInfo>
      <dependency>
         <dependentAssembly>
            <assemblyIdentity
               type="win32"
               version="6.0.0.0"
               language="*" />
      </dependency>
   </assembly>
Early on when I was testing 64 bit I noticed the same type of problem. In my reading of the documentation and other forums, I decided to go with the following manifest using a processorArchitecture="*"
<?xml version="1.0" encoding="UTF-8" standalone="yes" ?>
<assembly xmlns="urn:schemas-microsoft-com:asm.v1" manifestVersion="1.0">
    <assemblyIdentity
        version="1.0.0.0"
        name="Project1"
        type="win32" />
    <description></description>
    <dependency>
        <dependentAssembly>
            <assemblyIdentity
                type="win32"
                version="6.0.0.0"
                language="*" />
    </dependency>
       <security>
             <requestedExecutionLevel level="asInvoker" uiAccess="false" />
       </security>
    </trustInfo>
    <asmv3:application>
         <asmv3:windowsSettings xmlns="http://schemas.microsoft.com/SMI/2005/WindowsSettings">
</assembly>
Thanks very much. Now I can use the same manifest for both compilers.
         type="win32"/>
      <asmv3:application>
         <application>
         </application>
       </compatibility>
         <security>
                  level="asInvoker"
                  uiAccess="false"/>
         </security>
      </trustInfo>
      <dependency>
         <dependentAssembly>
            <assemblyIdentity
               type="win32"
               version="6.0.0.0"
               language="*" />
      </dependency>
   </assembly>
