Drag and Drop
Started by Anonymous, May 31, 2004, 03:15:20 PM
Anonymous
It would be nice if FireFly supported drag and drop onto the workspace dialog/Explorer window. Then when setting up a new project it would be easy to configure the default library code just by dragging it onto the explorer pane.
Having to configure each file separately is a bit of a pain.
This is a great feature in Visual Basic which I think would go down well with FireFly users.
Andrew
That is a real nice feature. I'll add it to my list. Thanks,
