WM_CONTEXTMENU for TreeView control never fire ?
Started by Jean-pierre Leroy, April 13, 2011, 11:16:27 AM
Jean-pierre Leroy
Dear FF Users,
I tried to create a ContextMenu when the user right-click on a TreeView control.
With ListView control I use the WM_CONTEXTMENU as well and it works well, but with TreeView control the message never fired ?
Is there any reason for that.
Jean-Pierre
Robert Eaton
Robert Eaton
Still not sure why WM_CONTEXTMENU doesn't seem to fire, but the second example in this link works using hittest.
http://www.powerbasic.com/support/pbforums/showthread.php?t=13144
