Kill a timer on form show
Started by Rick McNeely, April 18, 2011, 11:59:38 AM
Rick McNeely
I have a form with a timer on it.  I don't want the timer to run when the form loads.  I set the timers interval to 1000 mS at design time and tried to kill it before it times out using:
Function FRMREMOTECONFIG_CUSTOM ( _
    Select Case wMsg
        Case %WM_SHOWWINDOW
            KillTimer HWND_FRMREMOTECONFIG, IDC_FRMREMOTECONFIG_TBHOLDTIME
I also tried to kill the timer(s) during WM_CREATE, but it still runs.  What am I missing here?
Thanks
I think that the easiest approach in this case would be to create a global variable, say, gAllowTimer, and then in the WM_TIMER event handler have a line like:
If gAllowTimer = %FALSE Then Exit Function
Whenever you want to start/stop the timer then all you have to do is set the global variable to TRUE/FALSE.
