Toolbar Bug
Started by Anonymous, June 01, 2004, 05:36:19 AM
Anonymous
If you attempt to delete the first button from a toolbar (not a rebar) using the toolbar organize dialog the request is ignored by FireFly.
Deleting any other button works fine.
Andrew
Anonymous
Another small toolbar bug I've just discovered......
If you go to the organize dialog, click on a separator button definition in the listbox, then click insert (to insert a new toolbar button) the button style for the NEW button have the following radiobuttons checked:
TBSTYLE_BUTTON
TBSTYLE_SEP
Being grouped radiobuttons these should be mutually exclusive.
Andrew
Thanks Andrew,
I'll look into this and provide fixes ASAP.
Anonymous
Not urgent Paul - it'll do whenever the next upgrade comes out.
Andrew
